Philips FA-260 Integrated Amp
Username: Gchagemann
I have an old Philips FA-260 Integrated Amp and I want to buy new speakers for it however I do not access to the documentation for the device. All I know is that it is an 8 ohm device. Can any assist in terms of speaker watts etc..
Thanks
Gary H
Username: Frank_abela
Berkshire UK
Post Number: 3523
Gary, look for speakers which are designated as 8 ohm impedance and preferably 87db/w/m sensitivity or higher. The average speaker is considered to be 87db/w/m sensitive and 8 ohms. If your choice matches these two criteria or are higher in value (unlikely in the impedance case), then it should be an easy enough load for your amplifier.
