Naim loudspeaker plugs
Username: Lazoroski
Skopje, Macedonia Macedonia, T...
Post Number: 29
Hi,
For the past one hour I'm desperately struggling to connect the NacA5 to the supplied twin plugs that I got with my Nait 5i...Its damn difficult !
Any tips will be very welcome :-(
I can put the cable somehow and even close the plugs but I'm afraid that the connection is loose and that the wires might get in contact inside which would be very dangerous
As I'm desperate already I wonder do they really make a difference in sonic terms ?
Thanks and brgds,
Zoran
Username: Newnaimy
FFMFRG
You have to solder that plugs... they will not simply stick together on their own!!!
Username: Lazoroski
Post Number: 30
Thank you for the advice !
I thought of soldering but the Naca5 is very sturdy and not flexible so I don't think that soldering will keep it in place.
Do you have it soldered ?
Username: Newnaimy
FFMFRG
Yes, I did! I will post a picture of it tonight.
Username: Stu_pitt
Irvington, New York USA
Post Number: 3143
Naim dealers solder NACA5 for a small fee. Most solder them for free when you buy the wire and plugs.
Username: Frank_abela
Berkshire UK
Post Number: 3520
Zoran,
Your Naim dealer should have made up the connections for you. It's a job that takes some practice. Here's a description for how to do it off the Naim forum:
http://forums.naim-audio.com/eve/forums/a/tpc/f/3452929996/m/2922924807
As you can see from the description, soldering is the only way to ensure a good stable connection.
Naim plugs are definitely my preferred solution on Naim amps. other plugs are OK I guess but the Naim ones are very sturdy indeed and couple to the amplifier very well.
Username: Lazoroski
Post Number: 31
Thank you all !
Unfortunately I will have to do it by myself looking at the instructions from the Naim forum (thanks a lot Frank).
My Naim dealer is 400 km from where I live and when I bought the Nait 5i I already had the Naca5 that I used with the Rega Mira 3 in the past.
Brgds,
Zoran
Username: Nuck
Post Number: 11442
Good post frank.
Zoran, fire up the torch!
What do you have for solder?
Username: Pcstockton
Post Number: 223
Good point Nuck.
I do believe there is not only a prescribed method, but also a particular solder.
If I were you, I would do the research on how, and with what. Gather the needed materials, and bring to someone who KNOWS how to solder well.
It will be worth the $10 you pay an expert.
Berkshire UK
Post Number: 3551
Well, if you can find some of the thicker RS Components tin/lead solder it'll make life a bit easier than the unleaded version, simply because the leaded version has a lower melting point.
However, if you can't then use the tin/silver combination and put up with the flux...
