Bronze Member Username: J2maxmin007Post Number: 12 Registered: Nov-08 | Hello all again, i think that i have found the right sound system for my needs and under $500. One consern that i do have is listed under "Prouduct Info" there is a bullet that reads: 2 HDMI Inputs and 1 Output (1080p Pass-thru). I have no clue what that means and was wondering if it could turn into a problem. Also, i was wondering what commments you guys could make on the quality and of the Onkyo systems. Thanks as Ever |
Silver Member Username: EcousticsSan Francisco, CA USA Post Number: 234 Registered: Dec-03 | HDMI pass through means that audio can't be decoded from another HDMI source so you have to run a toslink (optical) or coaxial cable separately to the receiver. I am not sure which Onkyo model you're considering, but I believe the Onkyo HT-SP904 supports the latest HDMI 1.3a standard for full audio/video compatibility. |
Bronze Member Username: J2maxmin007Post Number: 13 Registered: Nov-08 | i was actually considering the Onkyo HT-SR800 7.1 Home Theater Entertainment System. So, does this mean that if i purchase this system i have to also buy a seperate Cable? |
Silver Member Username: EcousticsSan Francisco, CA USA Post Number: 235 Registered: Dec-03 | Yes, you would need a separate cable for audio. Did you see this review at CNET? |
Bronze Member Username: J2maxmin007Post Number: 14 Registered: Nov-08 | Wht Review?? Ok, well i found a cheap Digital Audio Optical TOSLink Cable on amazon. Would this do the Trick? |
Silver Member Username: EcousticsSan Francisco, CA USA Post Number: 236 Registered: Dec-03 | Yes, any toslink cable will work. |
Bronze Member Username: J2maxmin007Post Number: 15 Registered: Nov-08 | thank you |
