Wireless speaker help
Username: Mikkadrown
Iowa
I have a sharper image wireless Indoor/Outdoor speaker with transmitter. Problem is, there is no port on the tv to accomodate the cable that was sent with the transmitter. The tv is a 52" Samsung. There were no instructions with the speaker. I does say on the box that it can be used with a tv but certainly not with the cable they sent. The cable looks like one that would hook into an Ipod or MP3 player. Do I need an adaptor, a different cable or take the speaker back? Thanks for any help I can get!
Username: Jazzman71
Phoenix, AZ USA
Post Number: 420
Welcome Deb. Taking them back may not be an option as Sharper Image is in bankruptcy.
http://www.sharperimage.com/
Do you have a model number? Some of these plug into HT receivers. Others are made to plug into headphone jacks.
You may also want to try the Home Theater section as they may be more familiar with wireless speakers over there. Access it off the Message Boards tab.
You may be able to scare up a manual here, depending on what you have.
http://audio.manualsonline.com/manuals/mfg/sharper_image/sharper_image_wireless_ speaker_system_product_list.html
