Surround Sound Recievers in Stereo Mode?
Username: Millerw
MuskokaCanada
Post Number: 24
I've come across an nice deal on a 5.1 Yamaha HTR 5730, ($90) and I'm wondering how the 'stereo' setting works on surround receivers. I'm wondering if the 500W that the receiver has (and usually splits up 5 x 100W in surround) will become a 2 x 250W when I switch it to stereo.
http://www.yamaha.com/yec/products/productdetail.html?CNTID=200027&CTID=5000400& ATRID=1000&DETYP=ATTRIBUTE
(if that helps)
Thanks a lot!
Username: Jan_b_vigne
Dallas, TX
Post Number: 13159
Nope, it won't.
Username: Millerw
MuskokaCanada
Post Number: 25
OK, well how exactly does it work? Does it just send all info to the fronts and keep the power the same?
Username: Nuck
Post Number: 11212
You will get 1/5 of maximum power to the 2front speakers.
For that unit, it would equate to about 35 watts.
Username: Millerw
MuskokaCanada
Post Number: 26
Right on! Thanks, I'm gonna wait it out for a stereo rec.
Username: Nuck
Post Number: 11216
Save your pennies WM
Username: Nickelbut10
Post Number: 2125
Some higher end AVR's that have true wattage ratings per speaker when all speakers are being powered usually up say 100 watts to 120 watts per channel when only powering two channels. But for the most part they don't. Nuck is right, that Yamaha will only push a true 30-40 watts.
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 1765
A very anemic 35-40 watts at that. Like Nuck said, save yer pennies.
