Wht one is better?
Username: J2maxmin007
Post Number: 8
I was wondering is either this reciver: http://www.consumerdepot.com/products.asp?id=RD-6500D, or this one was a better choice: http://www.amazon.com/Sherwood-210-Watt-Stereo-Receiver-RX-4105/dp/B000MBUSD6 Both are either a set if Sony SS-B1000 5 1/8" Bookshelf Speakers or a pair of Boston Acoustics Horizon Series MCS100MDNT 5.1-Channel, mostly just for listening to music, thnx all!
Username: Jan_b_vigne
Dallas, TX
Post Number: 13151
Buy the Sherwood. If you don't ever want home theater with this set up, buy the stereo receiver.
Username: Mike3
Wylie, Tx USA
Post Number: 1598
The AVR for $79 has no remote. Not only that but on another thread you stated wanting to listen to music. Buy the Stereo Receiver and then you will just need 2 bookshelf speakers and a sub. You can always get the sub later when more funds become available.
Post Number: 9
thnx everyone, will do
Username: Exerciseguy
Brooklyn, NY United States
Post Number: 2221
http://www.buy.com/retail/product.asp?sku=202442741&listingid=34828995&dcaid=179 02
http://www.electronics-expo.com/make-a-store/item/SHERD6500/Sherwood/RD-6500/1.html
Either will do, and both come with a remote.
While I agree that if it's a music-specific set-up you're after, 2-channel is your best choice, you were looking for a 5.1 set-up for about $300, if you don't already have a DVD/CD player, then any "on-sale" name brand DVD/CD player, coupled with a Sherwood A/V Receiver, and the Boston Acoustics 5.1 speaker pkg. will be a significant upgrade, IMHO, than your afforementioned set-up.
If you do go down the 5.1 route, that Boston Acoustics deal @ Amazon is real sweet, the price is back down to $200 w/free shipping.
http://www.amazon.com/Boston-Acoustics-MCS100MDNT-5-1-Channel-System/dp/B000W9DO7U
Post Number: 2222
Here's another nice deal on an Onkyo TX-SR304
http://www.ecost.com/detail.aspx?edp=40236464&source=EWBBASE&cm_mmc=CSE-_-google -_-ewbbase-_-Electronics&ci_src=17588969&ci_sku=40236464
The Onkyo from eCOST will also save you a few $ on shipping.
Post Number: 10
thnk you, i have looked at all of these and i was also wondering about a whole system itslef. i found one a little more pricey then i want, but it seems to be good. i was wondering what u guys thought of it. http://www.amazon.com/Samsung-HT-TZ515T-5-1-Channel-Theater-Surround/dp/tech-data/B0015A6Y2C
i was also wondering about kicking in some extra bass so i found this sub-woofer http://www.amazon.com/Polk-Audio-10-Inch-Monitor-Subwoofer/dp/tech-data/B0002KVQBA
and was wondering if these 2 components were compatible. Thnks again
Post Number: 2223
Jacobian,
While I haven't heard that Samsung system, Samsung is not particularly well know known for audio. I am uncertain as to it's compatibility with the subwoofer, HTIBs can be a bit fussy about adding additional components.
In all honesty, I doubt you'll find a better 5.1 set-up for a moderate-sized room than the Onkyo (or Sherwood) & Boston Acoustics for under $300.
I'm not sure why you would want to spend more?
Those Boston Acoustic speakers are marked down from $600, and currently sell at several other websites for over $400 + s/h.
Post Number: 11
Ok, thank you very much,
i will look into all these things and get bak to you on the outcome
Post Number: 2224
Happy hunting.
