Speakers for home club
Username: Rossd
Los Angeles
We have a couple of rooms we use for parties 20x25. Many friends are house music DJ's so generally 90% electronic music and 10% Frank Sinatra :-). We want to stop using our large JBL monitors and mount speakers up high on the walls instead. Can anyone suggest some options for speakers that would sound good for this setup. A sub can be added if necessary but were not a "big booming bass" crowd. We were going to drive them off of a Yamaha 95wx7 receiver. Can anyone suggest a good value?
Ross
Username: Afj
GaboroneBotswana
Post Number: 151
cerwin vega could be one of your options
Username: Rossd
Los Angeles
We want to do white speakers as well. My thinking was to use a very nice outdoor model? That would give us the color and bracket we want. Francis or anyone else have any further suggestions?
Username: Afj
GaboroneBotswana
Post Number: 153
nothing that i know off ross. am sure someone else will be able to help though
Username: Rossd
Los Angeles
Ok, so obviously this is not that easy as I first hoped. Let me change course a bit and see if we cant get a solution. What pair of speakers, preferentially available in white would fill a room with sound much like a Bose 301?
R
Username: Afj
GaboroneBotswana
Post Number: 155
https://www.ecoustics.com/electronics/forum/home-audio/521663.html
check the link out. depending on your budget you can go one product line higher within each brand if you want a better quality sound
Username: Rossd
Los Angeles
Francis,
Your a scholar among men. That being said, it looks like you were dead on with the CV's a few days ago when I asked.
Thanks again!
R
Username: Afj
GaboroneBotswana
Post Number: 157
hardly ross. hope you come right
Username: Gavdawg
Albany, New York
Post Number: 1248
The bose won't hold up to what you are intending on doing. I would also recommend looking at Cerwin vega or taking a look at whaefedale zaldek (sp) speakers. The wharfedales are made for "home dj" use according to wharfedale.
