Klipsch RF10 and Yamaha RxV459
Username: I_am_kirk
Post Number: 46
I was thinking of getting some Blue Jeans cables for my speakers.
http://www.yamaha.co.jp/english/product/av/products/ht/rxv459.html
will give you a rear view (cable goes into a hole in side, then screw down.
Klipsch just have 2 sets of the black/red, connected with some metal jumper thing.
First off, would this be an improvement over my stock cable now (10 or 12 awg). Second, if it is an improvement, what terminations should I get.
I currently just use some Ultralink cables for stereo IC.
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 1644
If you're already using 10 AWG, I don't really see how switching over to Blue Jeans is going to be that noticeable.
Username: Jrbay
Livonia [Detroit area], Michigan USA
Post Number: 467
I agree you already have way more cable than you can possibly use!
You can learn more here:
http://customconnectionsonline.com/faq10.html
I really do welcome comments.
Username: Gavdawg
Albany, New York
Post Number: 1250
The most noticible thing you can do is to pair those speakers with a better receiver
Username: I_am_kirk
Post Number: 62
yeah. It was my first system. Guy seemed pretty good in the store and recommended this. It sounded pretty nice for the price (huge factor).
Username: Artk
Albany, Oregon USA
Post Number: 8149
If it sounds good to you that's what matters. Blue Jeans cables are very good upgrade on a budget from the stock ones that come with most budget gear. Terminations will depend what's convenient for you. I like bananas...however my van den Hul speaker cables have bus connectors and I can change them out. Enjoy your system.
