Username: Bikeman42 Grayson,
Ky
Usa
Post Number: 1 Registered: Oct-08
Sunday, October 19, 2008 - 18:21 GMT will the pro-ject speed box work with a music hall mmf-2.2 tt
Username: Jan_b_vigne Dallas,
TX
Post Number: 13066 Registered: May-04
Sunday, October 19, 2008 - 21:19 GMT . If the motors are the same voltage, speed and type, then you can interchange controllers. Any Speedbox dealer should be able to tell you which turntables the controller will work with and which it will not.
Username: Artk Albany,
Oregon
Post Number: 7916 Registered: Feb-05
Sunday, October 19, 2008 - 21:23 GMT Yes I'm using the Speed Box with my MH 2.2...works great.
Username: Stu_pitt Irvington,
New York
Post Number: 3073 Registered: May-05
Monday, October 20, 2008 - 00:19 GMT Not only will it work, but it'll make it sound so much better. Music Hall and Pro-Ject are built in the same factory and share many parts, motor included.
Ky
Usa
Post Number: 2 Registered: Oct-08
Monday, October 20, 2008 - 03:27 GMT thanks guys going to get me one.
Ky
Usa
Post Number: 3 Registered: Oct-08
Monday, October 20, 2008 - 03:29 GMT hey just wanted to say glad i found this site.alot of cool info on here.
Username: Nuck Post Number: 11000 Registered: Dec-04
Monday, October 20, 2008 - 10:24 GMT Good to see you Ty
