ADS L810 3/4" Soft Dome Tweeter
Username: Djhoch
I have a pair of ADS L810A speakers (the first generation of ADS manufactured Braun speakers). One of the 3/4" soft dome tweeters is not working. I checked the fuse and it is fine. I than switched the tweeters just to rule out any other possibility. One tweeter works fine, one is dead. Does anyone know where I can get a replacement set of ADS 3/4" soft dome tweeters?
Username: Jrbay
Livonia [Detroit area], Michigan USA
Post Number: 459
You can start here:
http://www.speakerex.com/
Good luck
Username: Jan_b_vigne
Dallas, TX
Post Number: 13067
You will have to search the flea market type web pages for an exact replacement from ADS and you still might come up empty handed. You would do better to try one of the DIY speaker component supliers such as Madisound or PartsExpress. They can supply a tweeter that will very likely have much better performance than the originals. You will have to replace the tweeter in both cabinets however.
Username: Ads_speakers
Phoenix, AZ USA
Need ADS speakers re-cone or rebuild please contact Richard So (ads_speakers@yahoo.com) Cell.480-452-9736
Phoenix, AZ 85040
Thank you,
Username: Nuck
Post Number: 11147
Whomever is posting their personal information, I suggest that you use a PM next time.
