Bose Lifestyle 20 woofer
Username: Denkees
I have bought a Bose lifestyle20 powered woofer LSM20CU102515 to use it as a woofer in a non Bose system. I don't have the cubes. I found the pin-out configuration of the 5-pin Din connector so i can connect it. Are the cubes also powered speakers or is there an amp in the woofers for the cubes ?
And does anyone know how to open the unit ?
Username: Nuck
Post Number: 10930
https://www.ecoustics.com/electronics/forum/home-audio/125990.html
Username: Scarab28xlt
Germany
Hello kees van loon,
can you help me im looking for the pin-out configuration of the 5-pin Din connector for my sub to connect the sub to a av-receiver.
Thanks for your help.
Username: Denkees
1= +12 volt don't need it
2= R- and L-
3= L+
5= R+
kees
Germany
Thank you for your fast help.
pin1 +12V is it for switch on the sub ??
Have you a picture, where i can see what are pin1 on the connector.
Username: Rishan1
I have a Lifestyl 5 Series III and I need to connect to my Audio Receiver how do i do that? with 5pin DIN connection
