Harman Kardon AVR 5000 memory loss
Username: Rawls
Perth, Western Aust... Australia
The input configuration memory has gone, cannot find batteries or capacitors or wiring diagram. Don't know what to do, can anyone help please.
Username: Nuck
Post Number: 10762
Marcus, it's time to call the factory for the default procedure.
You might give it a try, but I doubt that the AVR is like a SLC503, with a battery and short cap procedure.
Username: Eramsey
South carolina United States
Post Number: 586
The configuration settings,speaker settings,individual volumes,size,etc. are stored on a chipset and will remain even if the receiver is unplugged and not in use for a long period of time. Try the master reset, look in owners manual for this. It is usually just a matter of pressing and holding a couple of buttons. If this does not work consult an authorized repair center.
Username: Jan_b_vigne
Dallas, TX
Post Number: 12975
Unplug the receiver from the AC outlet for about one hour. Sometimes this clears the memory.
