Username: Zzzxtreme Post Number: 5 Registered: Aug-08
Wednesday, August 20, 2008 - 15:11 GMT hi i have 6 ohm speakers. and on a potential amp that im buying, there's a switch to select 8 or 4 ohm at the back. hmmm, must I only get 6ohm amps ?
Username: Dmitchell Ottawa,
Ontario
Post Number: 1311 Registered: Feb-07
Wednesday, August 20, 2008 - 15:16 GMT Should be ok. It's alright for the speakers to be higher than an amps minimum impedance. It's not ok for the speakers to be lower.
Username: Zzzxtreme Post Number: 6 Registered: Aug-08
Wednesday, August 20, 2008 - 15:24 GMT thanks a lot !!
Username: Stu_pitt Irvington,
New York
Post Number: 2954 Registered: May-05
Wednesday, August 20, 2008 - 18:26 GMT 6 ohm speakers will not stay at 6 ohms for any realistic length of time. Some speakers list them as 6 ohms, meaning a nominal impedence. A 6 ohm speaker may go as high as 16 ohms and as low as 4 ohms. See if they have a spec that says minimum inpedence. Some companies are more honest with these specs than others.
Username: Nuck Post Number: 10664 Registered: Dec-04
Wednesday, August 20, 2008 - 23:17 GMT If you select 4 ohms, the current will be limited and you should be safe.
Username: Frank_abela Berkshire
UK
Post Number: 3177 Registered: Sep-04
Thursday, August 21, 2008 - 15:26 GMT Correct - if you buy 6-ohm speakers, set your amp to the 4-ohm setting and you'll be fine.
