I just wondered what it would actually sound like.
I could probably just add a diode in-line with a pair of speakers that are paralleled (should not change effective impedance much). The effects would probably be pretty interesting. In fact, I'll probably end up doing this since I can't think of any problems it would cause in terms of amp stability.
It'd just be pulsing dc on each driver.
I just wonder if it even works. I'll have to try it.
Since no responded saying not to, I got ahold of some diodes (50v, 6A). 4 to be exact.
The forward voltage drop was .477v (measured), so I figured anything below that wouldn't even each the speakers. Yep. It sounded like extreme crossover distortion, yet I heard the music. Out of an amp that has the + and - signals reaching the speakers down to 0v, it would probably sound much better.
Anyway.. The reason I got these diodes was to make a rectifier for a transformer I have.
I'll probably use my 4700uf (35v, the DC output of the transformer could be above 35v..I'd have to measure the unloaded voltage and take into account the diode drops) cap with it.
