Amp for the JBL L890
Username: Jxl
Hi everybody, i was just wondering which amp would go best with these speakers at low/mid/high volumes without risking damage to the speakers...
If you had to choose between NAD C325BEE and NAD C352, which would you think would be more adequate for the above mentioned speakers?
Username: Jan_b_vigne
Dallas, TX
Post Number: 12837
You don't need power with those speakers. Buy cheap and spend the rest on new music.
Username: Afj
GaboroneBotswana
Post Number: 95
i;ve got the 890's and powering it with a nad c272. playing it really really loud i've managed to clip it. so if you;ve got a big room and want to boogie once in a while IMO you'll need the c272 or c372
