Silver Member Username: TpizzlePost Number: 530 Registered: Apr-05 | I just purchased a new Energy Encore 8 today and was just making sure I get everything together before I receive it. Is the cable connecting the receiver to the sub the only thing needed? What brand of cable should I be looking for? Thanks |
Silver Member Username: MagfanUSA Post Number: 292 Registered: Oct-07 | good outlet? couple of places to park it for test before final placement? |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 12823 Registered: May-04 | . You will need a search engine with the words "subwoofer placement" typed into the box. For now, a good cable from any manufacturer will suffice. |
Silver Member Username: MagfanUSA Post Number: 295 Registered: Oct-07 | http://www.klipschcorner.com/Tools/ModeCalc.aspx Not that you can do much about the dimensions of an existing room, but here is a link to a room mode calculator. This information can help with initial placement. |
