Sampling Rate on DAC
Username: Eddietfman
Hong Kong
Post Number: 41
My DAC was accepting 32-96KHz sampling rate. However, after modified by adding a Re-clock module, it was locked to a 44.1KHz sampling rate. I was told that the source of a CD was of 44.1KHz sampling rate only so its not necessarily to have up to 96KHz sampling on the DAC. But now my concern arises that if I am to use this DAC with DVD disc, is there any adverse effect given that the sound source of DVD disc is of 48KHz and some is of 96KHz?
Username: Pcstockton
Post Number: 142
i am fairly sure you will more esponses to your questions if you posted it in the DAC section of this site.
As far as I can tell there is no amplifier question here.
