Klipsch RF-62 or Polk Audio TSI500
Username: Hddvd
Post Number: 30
I am looking for some new speakers and i am stuck between these two. I get get them both for fairly cheap. Which one do you think will be better? I am looking for loudness and clarity.
Username: Petergalbraith
Post Number: 2181
http://www.polkaudio.com/homeaudio/specs/individual/floorstanding/tsi500/
http://www.klipsch.com/products/details/rf-62.aspx
The Klipsch are rated to play 6 dB louder for the same input power; i.e. the Polk need 4 times as much power to play as loud.
But I wouldn't base a buying decision on that alone. There's not way you can hear them both?
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 1061
For HT or music?
Username: Dmitchell
Post Number: 1063
I've owned both brands.
Based on build quality I'd go with Polk. based on sound quality I'd go with Klipsch.
It depends a lot on your source gear, too.
Username: Hddvd
Post Number: 31
sorry that i havnt had a chance to reply. This is the receiver that i plan on using:
http://www.yamaha.com/yec/products/productdetail.html?CNTID=558291&CTID=5000300
i plan on using this setup mainly for HT.
Username: Serniter
Piscataway, New Jersey USA
Post Number: 209
If you want the system to play loud, pay attention also to room characteristics. Room size and how 'live' it is can influence your speaker decision.
Username: Nuck
Post Number: 10394
Hi again, Srinivas
I missed Piscatway, like Far Rockaway.
Username: Serniter
Post Number: 210
Hi Nuck, I pop in sometimes to contribute to threads within my league. Rest of the time, I'm just lurking... It seems to be getting quiet on the forum??
Username: Dmitchell
Post Number: 1070
It does seem a little quiet lately.
Username: Gavdawg
Albany, New York
Post Number: 1178
If you are looking at using yamaha, I would also recommend looking at Paradigm and Energy speakers as well. They blend better with Yamaha than the Klipsch IMHO.
Username: Dmitchell
Post Number: 1074
Paradigms or Energys would smooth out the Yamaha nicely.
Yamaha and Klipsch together would only sound good if you like the sound of metal garbage cans being dragged down the street behind your car.
Username: Hddvd
Post Number: 32
what about yamaha and the polks??
Username: Mikew
Post Number: 18
Ravindra,
Since you are saying HT, Klipsch reference are very very good for HT.
If you plan to use it for music & HT, Paradigm studios can do a better job as they are more all round speakers.
You can also make klipsch good for Music by adding some tube integrateds like Jolida / Sophia Electric at a later time for $400 on Audiogon.
Also, for HT with klipsch...Yamaha is a bad choice. Harman kardon, Marantz are two lines that work better with Klipsch...even Pioneer. I am not sure what your budget is....But you can do better using some medium priced HT reciever from H/K and then add some pre-owned 3 channel amps from B&K / Parasound (from Audiogon) to create an awesome HT set-up. B&K and Parasound have very good synergy with Klipsch speakers.
If you need more directed feedback, let folks know the budget you are working with and you will see some very nice suggestions from folks on this great forum.
Mike
Username: Nuck
Post Number: 10411
Attaboy Mike, wave the flag
Username: Doogxela
Indianapolis, IN U.S.A.
I'm this close to buying the same speakers and receiver the original poster talks about. This is the first time I've run across someone saying that Yamaha receivers don't play well with Klipsch speakers, but this thread reads as if this were a commonly known thing. Could someone elaborate on this? Are there already threads that cover this I could be pointed to?
Username: Gavdawg
Albany, New York
Post Number: 1184
certain yamaha receivers are on the bright side... likewise the same can be said about klipsch speakers.
Supposedly the newer yamaha stuff isn't as bright, but the older stuff was terrible.
Username: Mikew
Post Number: 19
Alex,
Klipsch speakersa re dynamic and are on the brighter side. That siw hy they fit HT needs very very well. Majority of the Yamaha Recievers are also on the brighter side. That does not mean Yamaha recievers are bad...they do go well with some laid back speakers. But pairing up brighter yamahas with brighter klipsch will make the system sound too harsh.
Mike
Username: Dmitchell
Post Number: 1157
Mike in right on the money. My Yamaha receiver actually sounds pretty darned with my PSB speakers.
Username: Nuck
Post Number: 10506
I didn't hear/understand that.
Really.
Username: Dmitchell
Post Number: 1159
Ah... thanks Nuck. lol... "pretty darned GOOD".
My brain works faster than my keyboard. Which I guess is not really saying too much.
Username: Artk
Albany, Oregon USA
Post Number: 7249
My Yammie works well in the HT role which it is filling. But with older warmer sounding speakers (at least the mains)
Username: Dmitchell
Post Number: 1160
That's exactly what I was trying to say.
Username: Artk
Albany, Oregon USA
Post Number: 7251
....I knew that...lol!
Post Number: 2183
OTOH, lots of people on the Klipsch forums enjoy their Yamaha receivers.
Username: Dmitchell
Post Number: 1163
They're obviously nuts.
Joking.
Sort of.
