Turntable belt size?
Username: Guitaristbryan
hey everyone,
how do i find out what size of belt i need for my turntable?
i've heard of a method involving a string, but how exactly to i tell how long i need?
i have a technics sl-b202.
thanks!
Username: Artk
Albany, Oregon USA
Post Number: 6974
http://www.turntableneedles.com/index.asp?PageAction=VIEWCATS&Category=18849
http://www.turntableneedles.com/index.asp?PageAction=VIEWCATS&Category=20699
Username: Nuck
Post Number: 10315
Bryan, you can use the string if you wish. You must know the diameter of the pulleys, the thickness of the belt, the pitch of the belt, the precise centre to centre distance between the pulley center...and a slide rule.
Or use Art's links.
Username: Frank_abela
Berkshire UK
Post Number: 2981
Slide rule ... Nuck, you're showing your age.
And to really twist the knife, Bryan will respond wondering what a slide rule is.
Username: Nuck
Post Number: 10320
Aww heck, what's a forum if not lacking in division, anyhow?
