I need a new Remote for a Harman Kardon AVR35
Greg
Does anyone know where I can purchase a remote for a Harman Kardon AVR35? Some of the units functions will not work without the remote.
Hawk
You can usually get these things directly from the manufacturer. Check out the tech support section at www.harmankardon.com. E-mail them if you have to and they will direct you to where you can get another one.
