Newbie needs help, please
Username: Baot1234
LAWRENCEVILLE, GA USA
can i use 1 subwoofer for both amplifier and receiver? if yes, please advice how. Thanks
Username: Jan_b_vigne
Dallas, TX
Post Number: 12644
It's not advisable to allow a possible common connection point between two amplifiers. It can be done but requires some care. Why do you want to do this?
Username: Baot1234
Thanks for your quick respond. Because I have a receiver for home theater now, but it's not for karaoke and I also want to set up karaoke system. If able to do that then I'll buy a karaoke amplifier to set it up.
You stated that REQUIRES SOME CARE, can you be specified about REQUIRES SOME CARE? Thanks in advance.
Dallas, TX
Post Number: 12646
You can never allow the two amplifiers to see each other while powered up. Place "Parts Express" in a search engine and give them a call for the appropriate switch.
