Having an issue with my Infinity center channel speaker
Username: Timver
I have an Infinity center channel speaker (Not sure on model)and two rear Bose speakers (the two small cubes). For a Tunner I have a Pioneer VSXD1S, I have been having an issue with the center channel and need some help. What happens is I will be watching TV, Movie ect and sound is great then center channel audio goes to a lower volume for anywhere from a minute to 3 minutes and then it goes back to normal for ever sometimes or 30 minutes and then back to low and so on. What is doing this I checked the cable and it is fine.
Thanks
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 925
I doubt it's your speaker. More likely the center channel section on your receiver that's acting up.
Username: Timver
how do I check it to see if it is and fix it?
Username: Dmitchell
Post Number: 926
You could swap out one of your front speakers for the center and see if the same behavior continues. If it does, then you know it's the receiver and not the speaker.
Username: Timver
Ok so far no front speaker, I just have center and two rear speakers. Ideas on two nice center channel speaker and a sub? Also if it is the tunner, what is a nice one to replace it with? Thanks
Username: Dmitchell
Post Number: 927
That's a rather unconventional setup you have there Tim.
Did you mean ideas on two nice front speakers?
How old is the receiver?
Username: Timver
Yes, Ideas on front speakers and a sub woffer.
The reciever was bought back in 1991, so it is old but has a ton of hook up's and options. Pioneer makes nice stuff, I think.
Thanks
Username: Dmitchell
Post Number: 928
I have a Pioneer too. I like it.
But seriously, time to pick up a new receiver.
Username: Timver
Ok so what do you recomend for a recieiver,front speakers and a sub??
Packages or all by themselves is ok.
Thanks
