New member Username: Brian_maysPost Number: 1 Registered: Apr-08 | I have a turntable to digitize old family albums. On some of the albums the auto shut off thinks the album is completed before it actually is. The arm will raise and return back to the starting position before the record has finished playing. I find no way to adjust this outside...wonder if there might be some suggestions? Here is the model I have. http://www.presentsforyou.com/nr305ttemerson.html |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 12555 Registered: May-04 | . This player has had a fair number of problems reported to this forum. The only way to solve these problems is through a technician. Usually the unit has to be sent away for repairs. If you have your receipt and it is still in warranty, send it off. . |
