REGA MIRA3-PROBLEM
Username: Mirod
Hi all,
I have problem with this amp. After 2-3 hours i can hear a noisy crack from one speaker.This is my second rega mira3 whith the same problem. Did anybody have this kind of issue whith rega.
Thanks for your advice
MiroD
Username: Nuck
Post Number: 10083
MD, is this unit a replacement for an original Rega with the same problem?
Username: Mirod
Yes, it is replacement with the same problems.First one had problem with left channel and now i have this problem with right channel.
Username: Nuck
Post Number: 10085
How very odd.
Have you refreshed your speaker runs in the last while?
Username: Artk
Albany, Oregon USA
Post Number: 6729
I have a 3 and haven't had any issues at all...sorry to hear that you are. If you determine that it's the 3 then work with your dealer for resolution if they are difficult then call the distributor directly...The Sound Organization in Dallas and they will help. Good Luck.
Username: Mirod
I tried differend cables and speakers with same results.
