Will power double using 2 amps pre-out / amp-in?
Username: Falcon147
Q.
1. Will I double the power using two identical amps preamp out of amp 1 out to amp in of amp 2 and preamp out of 2 to amp in of 1 without frying out everything<<<<
If not do I use the amps in a crossover situation in order to double or add power? Are there any other simple otions.
Wayne
Username: Jan_b_vigne
Dallas, TX
Post Number: 12437
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 843
Not sure I understand the question. Why not just buy one amp that has sufficient power? How much power ya figure you need anyway?
Username: Falcon147
First, I am not real sharp on the preamp stuff.
400 watts would be great.
I have 2 two hundred watt amps same model @ 100 watts per chan ea. both have pre out and amp in.
Is this applicable re: my first Q. ?
Is there a better application to use these connections?
I am running everything through a 12 chanl mixer.
