New member Username: Nickandersonbc
Post Number: 1 Registered: Jun-04
Posted on My subwoofer started buzzing the other day and its driving me mad. I disconnected it and it is still buzzing with only the power connected |
J. Vigne Unregistered guest |
Posted on Sounds like a bad power supply capacitor. Needs professional assistance. Unless it buzzes with the power disconnected, then it needs an exorcist. |
Silver Member Username: Kegger
MICHIGAN
Post Number: 397 Registered: Dec-03
Posted on now you say it buzzes with only the power connected. you don't by chance still have the rca input cable connected or anything else do you? because a bad/ shorted or non shielded cable will do this also. you might even want to check all connections for any foriegn material across any connections that might cause this interferiance. if that fails you could try to take it apart and make sure there is nothing inside the unit accross any connections like a screw or piece of wire. |
Post Number: 2 Registered: Jun-04
Posted on Thanks for the suggestions guys I will take it apart and have a look. |
