will Unregistered guest | can anyone compare these 2 amp. both of them are of similar price thanks |
Bronze Member Username: PalPune, Maharashtra India Post Number: 25 Registered: Apr-04 | https://www.ecoustics.com/electronics/forum/home-audio/10807.html Hope this helps !! |
Bronze Member Username: PalPune, Maharashtra India Post Number: 26 Registered: Apr-04 | But make sure u read it till the end ![]() |
New member Username: Tons_of_funLondonUK Post Number: 2 Registered: Jun-04 | From a manufacturer perspective (Cambridge) we were much more impressed by the 352 than the 320 (which we see as a 540A competitor) and feel that whichever one you choose would come down to pure personal preferance. I will say that if you are married or otherwise attached, ladies always fall for our remote so your choice may be influenced! |
Silver Member Username: ValeemPost Number: 103 Registered: Dec-03 | Yeah sure it has a nice remote but I never heard it once! |
Silver Member Username: ValeemPost Number: 104 Registered: Dec-03 | Oh I forgot to ask have Cambridge any plans to do us a reasonably priced pre/power for HT? |
New member Username: Tons_of_funLondonUK Post Number: 7 Registered: Jun-04 | It is ridiculously early days in our AV program- the 540R is literally the first product from the DSP team (whom we're still recruiting) and the first priority is a broader range of integrated AVR's but there is certainly some strong thoughts in that direction. |
John Reynolds Unregistered guest | Ed, Just noticed that you're something to do with Cambridge Audio? Now this is off-topic I know but I have a slight problem with one of your DAB tuners - the DAB300 to be precise. It's the second one I've had from Richer Sounds, the first was returned for the same fault - namely that the unit switches itself on and off automatically whenever it feels like it. This problem is so bad that I have to unplug the tuner from the mains when I'm not using it! Aside from this, the unit is great - really nice sound to it. Just wondered if you can check as to whether any others have been returned for the same problem and if you managed to work out how to fix it? Richer Sounds reckoned it's the first they've heard of it yet both mine have done it. If you can tell me that it's widespread and that you've managed to fix the problem then I can go to Richers and tell them EXACTLY what's wrong with it and get it fixed! I'd appreciate your input on this Ed because it can't be anything major but it's one HELL of a pain in the butt! |
