Reciver inputs. Composite or S-Video?
Username: Threeheaddog
I have Kenwood vr-716 from HTIAB.HTB-406
http://www.kenwoodusa.com/product/product.jsp?productId=2543
says 3 composite inputs but I dont see them on back.
using Svideo now. Do I want Composite?
Also have jbl powered 10" sub. how do I hook up.
running it split off the mains currently.ok?
Username: Cornboy
Do you mean componant? Composite are RCA jacks, red, yellow and white.
Username: Project6
Post Number: 627
No, you don't want composite. Composite is that one yellow jack that carries all the color signals in one output. S-Video has better resolution and component is the best of the three.
You should have a subwoofer or LFE output on the Kenwood. Use that to hook up your powered sub. Don't split it off the mains.
I dont have pre out. now what?
I meant component video inputs. Theres none..
Username: Project6
Post Number: 629
a w,
Use the jack meant for the Kenwood's powered subwoofer
If you don't have component video on the receiver, you'll be fine. What you want to do is go directly from the DVD video outputs to the video inputs of the TV. Its a better connection in general.
hey Berny,
line level sub speaker out?
versus,
low level sub out,
which is better. why?
Username: John_a
Post Number: 1344
aw,
There is a lot on sub connections on other threads. There is no simple answer. It all depends on what, exactly, you want the sub to do. Try "Search" on this forum. But, as with composite/S-video, why not just try it and see? I think you will find S-video wins hands-down.
