newbie04 Unregistered guest |
Posted on Is it true that optical cable connection is for watching movie and coxial cable connection is for music listening? If I connect the dvd player which has built-in dts decoder to the av receiver by using the digital outputs, does the receiver decode it again? |
Silver Member Username: Landroval
Post Number: 229 Registered: Feb-04
Posted on No, optical and coaxial will do exactly the same thing. If you connect the dvd-player to the receiver with a digital connection, only the receiver will do the decoding. |
