Amp for infinity kappa perfect?
timmy
I need an amp for this sub right here:
Kappa Perfect10
Configuration: 10" subwoofer
Nominal Impedance: 4 Ohms
Power Handling: 350W rms 1400W peak
Sensitivity @2.83V/1m: 94dB in-car @ 40Hz
Frequency Response: 18 -- 200Hz
Mounting Depth: 5-7/8" (150mm)
Cut-out Diameter: 9-1/8" (232mm)
Would something like this polk 550x1 be good for it? http://www.polkaudio.com/car/specs.php?name=c300_2
Or to much power?
How bout this infinity amp?
http://www.circuitcity.com/detail.jsp?c=1&b=g&u=c&catoid=-8865&qp=0051609103622& oid=92940&m=0
This is all pretty confusing with all the choices.
Would it be better to get a lower rated sub mono amp or a higher powered amp bridged into one channel?
