Bronze Member Username: PhenolitePost Number: 17 Registered: May-04 | So, my setup is a high end stereo system - NAD separates and PSB speakers. Now, i realize dvd-a is multichannel (basically, a CD with Dolby), correct? Also, the quality is said to be much higher than cd, because of space, etc. Now, Can my NAD stereo system (no digital stuff) take advantage of DVD-A properly or should I just get a DVD player that doesn't have DVD-A for now? I want a dvd player bad because my PS2 is such a horrible....everything...as far as home theater goes. thanks!!! |
Silver Member Username: SemPost Number: 110 Registered: Mar-04 | dan b, DVD-A will not play on a regular cd player. You'll need to play it on a dvd player. All the DVD-A's I've seen include a DTS layer, and both 2 channel and 5.1 channel hi-rez. Most all dvd players now can decode and play DTS, via the analog connects or send the digital signal to a DTS capable receiver to decode. But only players specifically designed to decode DVD-A can play the high-rez, via the analog connects. |
Silver Member Username: GmanMt. Pleasant, SC Post Number: 546 Registered: Dec-03 | Dan- Not only will you need a DVD player that has DVD-A capability (although it will play on a standard dvd player--just not up to its capability)--but you will need an AV surround receiver and at least a 5.1 set-up. If you don't want to buy that many speakers and an AV receiver or AV preamp/multi-channel amplifer it is undoubtedly a waste of money to get involved with surround formats. But at least with a dvd player you can watch movies in stereo with your current set-up or listen to dvd-A's in stereo. Actually, you can get an inexpensive Sony DVD player with SACD, as there are quite a few SACD recordings in stereo. |
Silver Member Username: KeggerMICHIGAN Post Number: 356 Registered: Dec-03 | dan the answer would be yes. you can play both dvd-a and scad in 2 channel stereo with 2 analog rca connections. and i highly recomend it. me personally i would buy a universal dvd player like the denon 2200 so you can take advantage of both high resolution formats. |
Silver Member Username: KeggerMICHIGAN Post Number: 357 Registered: Dec-03 | or like gregory said you can go the inexpensive route on the player. i also have the pioneer 563a $140 from best buy that will play both "sacd and dvd-audio" (mispelled on previos post) this player works fine and plays nice not quite as good of sound quality as the denon but still much better than cd! |
Bronze Member Username: PhenolitePost Number: 18 Registered: May-04 | Well, currently, I have a Playstation2 for DVD AND CD ![]() Kegger (lovely name, btw ![]() How do you like the 563? I have read some reviews and honestly I am highly considering it. I want to get a universal player, so I won't have to replace it, but, since I opted for stereo, I think the pioneer is a good choice for a budget-minded person. I am curious how well it plays CDs - I assume anything is better than the Playstation2? lol thanks guys, awesome advice as usual!! |
Silver Member Username: KeggerMICHIGAN Post Number: 359 Registered: Dec-03 | for the budget minded i think the unit is great. it plays cd's fine and all the different media formats you might try including copied media. and it's a very good dvd video source also. "for the price" |
Silver Member Username: SemPost Number: 112 Registered: Mar-04 | dan, I have a 563-A as well, and agree with Kegger. Tough to beat as far as versatility, "for the price." Of special note, evidentally there is an issue with this model not being able to play certain DVD-A's - Steely Dan's Gaucho for one. From what I hear its easily fixed by way of a firmware upgrade. Unfortunately its not a DIY upgrade, you have to take it or send it to a service center. Reminds me...I think i'll pick up Gaucho, both as a test to see if mine has been upgraded, and also because I love the album. |
Bronze Member Username: PhenoliteRochester, NY Post Number: 19 Registered: May-04 | Not sure which way I want to go (budget or no budget). I bought my audio setup just this past Friday. I got stereo because I do not have a good room layout for multichannel and i got the NAD stuff at a real good deal. Well I am making this thread turn into a DVD player thread, not a DVD-A thread. so i'll shut up now ;) |
Gold Member Username: John_aPost Number: 1294 Registered: Dec-03 | dan b, Thread: Twilight of the compact disc |
Bronze Member Username: DonaldekellyWashington, DC Post Number: 12 Registered: Jul-04 | DVD-Audio on Pioneer 563-A Not so hot? I have a well reviewed Beethoven dvd Audio (actually 3 of them) by Abbado. The sound on this DVD-A is supposed to be 9 out of 10. I have regular cds that sound better. Maybe I hooked up my Pioneer 563-A wrong? SACDs sound pretty good. I am playing both in stereo currently- I do need a new receiver to get better sound and to get surround sound. It is on the way. |
Silver Member Username: KeggerMICHIGAN Post Number: 765 Registered: Dec-03 | mine works just great on dvd-a. all of my speakers are set to large with sub on. maybe that will help. |
Bronze Member Username: DonaldekellyWashington, DC Post Number: 14 Registered: Jul-04 | "all of my speakers are set to large with sub on" you mean on the receiver? Or on the dvd player? I did not see a way to set them on the dvd player (I did not choose surround set up cause I don't have it yet. Soon I will.) |
Silver Member Username: KeggerMICHIGAN Post Number: 772 Registered: Dec-03 | on the dvd player. even in 2 channel it can use the sub and bass management. you have to do it with no disk in the unit and go into either advanced setup or initial setup. it's been a while since i fiddled with mine but it does play dvd-a's very nice. some disks do sound better than others. and some people say a disk sounds good not just the equalization or record quality but by how well it is mixed for multi channel. so just because the sound is suppose to be 9 out of 10 doesn't nessacarily mean really clear or well eq'd. i have not heard that disk so i can't tell you. |
Bronze Member Username: DonaldekellyWashington, DC Post Number: 15 Registered: Jul-04 | Thanks Kegger I haven't read through the entire manual - I thought I had it set up right. I will try without a disk in it. |
Bronze Member Username: DonaldekellyWashington, DC Post Number: 22 Registered: Jul-04 | New onkyo receiver makes every disc sound great. DVD-audio problem is gone I think. |
