I have setup my zone 2 for T773 through the surround back speakers as advised on this forum. This works perfectly through the VCR setting, but will not play through the DVD? I assume its to do with my setup? Has anyone come across this? Any suggestions? Thanks
I suspect it is because zone 2 only accepts analog inputs. If you have an HDMI, digital coax, or optical input from your DVD try switching it to RCA inputs to your T773 then see if it plays in zone 2.
This recommendation is based on my zone 2 experience with my Denon.
