Best 5 /6 speaker system with NO .1 ( no Subwoofer)
I recently got Onkyo TS SR601 and now I am looking for 5 or 6 speaker system without a subwoofer. Actually I'll be taking this system to India and carrying a sub will not be that easy.
So I am planning to buy a decent sub in India.
I could find only RM 6700 from polk audio which sell 5 speaker system without adding sub in the package. You have a freedom to choose your sub. I heard 6700 speakers in local CC store and they sounded really good.
Also I would like to know if I buy a sub from other vendor how will it affect the overall sound quality?
Mu budget is under $600.
Please advice,
Thanks,
Pushpinder
You should be fine...those are pretty decent units. The subwoofer quality depends on the type you will be getting and it should not affect the sound of the other units that you purchased, it will, however affect the over all sound of the home theater so choose well.
