Speaker Connections
Username: Nrgetic
So I have a set of klipsch promedia ultra speakers using spring clip connectors (the sub has died rendering system uesless)... i dont have the budget right now to buy a WHOLE home theater system but i can pick up a sub and a receiver.
if i bought a receiver, and all that i saw in stores uses RCA type connections, how can i connect those spring clip type speakers? any adapter i can buy? and will running these low power speakers under a higher powered sub damage them?
thanks in advance
Username: Stryvn
Wisconsin
Post Number: 686
I love this.
Bill Gates doesn't know how to connect electronics nor does he have the extra scratch to get a HTIB.
Username: Nrgetic
haha. well not this gates :-)
Username: Wattsssup
Barrie, ON Canada
Post Number: 222
stocks are down.
Username: My_rantz
Australia
Post Number: 1857
Bill, those receivers you saw would have RCA component inputs/outputs, but should have normal binding post speaker terminals that would allow you to bare wire your speakers and still use the spring clips on your speakers. If they don't well I'd be flabbergasted.
And if you are getting a new sub, it should have it's own amplification and control to favour your speakers.
Speak to your dealer.
