Balanced outputs?
Username: Magfan
Post Number: 142
Are there any advantages to Balanced outputs on a CD player? I see these on the CA 840, but none other, at least in the sub-stratospheric price range.
Going forward, does this unit have a good enough D/A section to be considered a long term keeper? Will it take the input from an I-pod? (reach!)
Username: Nuck
Post Number: 9872
Sure, Leo, the benefits of properly balanced stages are the same from componant to componant. Lowered noise floor, seperation of channels and earths, and a boost of about 6db in signal.
Username: Stu_pitt
Irvington, New York USA
Post Number: 2523
If they're done correctly and not just for show Nuck.
The iPod doesn't have a digital output, therefore making the DAC in the Cambridge a non-issue in this case. Is it good enough as a long term keeper? I don't think anyone can really answer that.
Username: Jaw
Post Number: 189
http://www.soundstageav.com/onhifi/20070801.htm
Username: Stu_pitt
Post Number: 2527
I think Red Wine Audio, MBL, and Krell modify iPods in a similar manner.
For the money, I think the CD players with internal hard discs will be better. I can't recall who makes them. McIntosh has had one for a while now.
Username: Jazzman71
Phoenix, AZ USA
Post Number: 70
Some more info on music servers FWIW:
http://www.garrett-smarthome.com/articles/audio-video/musicservers.htm
http://www.avrev.com/equip/musicservers.html
http://www.audioclassics.com/cat.php3?cat=CD+DVD+LV+LD+Players&p=1
Several different types and mfrs. Stu, Mac makes 300-gig and 750-gig versions (possibly more now).
Username: Frank_abela
Berkshire UK
Post Number: 2772
I cannot understand the domestic HiFi scene's steadfast refusal to adopt balanced connections more widely. Every time I have listened to properly balanced components they appear to improve significantly over similarly priced single-ended brethren. It's unfair to compare a unit's balanced and unbalanced outputs of course, since the unit will be optimised to work in one of those modes.
Username: Nuck
Post Number: 9880
Again, the blance issue appears. Even the most modesr pro gear is balanced, a lot offers only that connection.
If a 200$active XO from Behringer can do it, why not a Rega or Yamaha?
One phono stage that I am eyeing is balanced, but at 1k$ is about as cheap as you will find by a long shot.
Berkshire UK
Post Number: 2775
Nuck
Is that phono stage with balanced inputs as well? One of the things about balanced operation is you really need to be balanced all the way through otherwise the noise floor rises again. It is possible to wire up a tonearm with such that each lead (lef pos, left neg, right pos and right neg) is individually connected to an active portion of the phono stageallowing for balanced operation throughout the phono stage. The only manufacturer I know of who can cope with this kind of input on their phono stage is Chord Electronics with their Symphonic. Have a look here:
http://www.chordelectronics.co.uk/products_detail.asp?id=8
Regards,
Frank.
Username: Nuck
Post Number: 9881
TYVM Frank. I am going to wire the phono that way, but I need to understand the point to point connections from PSAudio as well.
I will look into it. The phono and trans dac will be fully balanced all the way through then.
Berkshire UK
Post Number: 2779
Nuck,
The point was that the phono stage would have to have the appropriate inputs. It has balanced outputs but will it have 4 RCA inputs or XLR inputs for appropriately wired tonearms?
Regards,
Frank.
