New receiver or amp?
Username: Crazyloof
Post Number: 7
Alright... first off I'm an uber noob to receivers and home audio and what not. I'm looking for a receiver within 225$ that will put out a good amount of wattage. I'm going to be hooking up a pair of Bose sattelite speakers, Pioneer CS-G205 floor standing speakers, and this subwoofer : http://www.amazon.com/Sony-SA-W3800-Performance-200-Watt-Subwoofer/dp/B000OKZXSU . Suggestions?
Username: Crazyloof
Post Number: 8
Also that subwoofer is 200W RMS and I'm not sure how the receiver power works really, but I want to get the full effect from the subwoofer (the subwoofer also has an amp built on so.... I'm a tad confused)
Username: Shawnharman
Post Number: 172
if you can stretch a little check this out http://www.bestbuy.com/site/olspage.jsp?skuId=8258501&type=product&id=1170289629 617
dont be to worried about the amount of watts it has.
it will give you more than enough power to drive those speakers.
the sub you have is a powered sub, which means it uses its own amp to power it and in return takes the strain off the receiver.
Post Number: 173
sorry about the link doent seem to be working, here is another place with the same receiver, but at a lot better price, so you wont need to stretch your budget.
http://www.bhphotovideo.com/c/product/488992-REG/Harman_Kardon_AVR146_AVR_146_Ho me_Theater_Receiver.html
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 702
H/K tend to rate their power output conservatively. The AVR146 at 40w will be more than enough.
