New member Username: CrazyloofPost Number: 4 Registered: Feb-08 | Any suggestions are the subwoofer that would give me the most bass for 175$... suggestions only please none of that "well for 250$ you can get something uber leet". |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 6452 Registered: Feb-05 | Buy used....check Audiogon and Videogon. BTW that is a suggestion. |
New member Username: CrazyloofPost Number: 5 Registered: Feb-08 | Does anyone have a specific subwoofer in that range though? |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 6453 Registered: Feb-05 | Check the resources mentioned like Agon and Vgon and ask questions relative to specific product that happens to be available...for instance a Martin Logan Dynamo might be for sale near your budget if so then ask about it specifically. I think it's pretty much a consensus here that there isn't anything worth buying in your price range new, so we have to know what you're looking at used to give an informed response. |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 6454 Registered: Feb-05 | http://www.audioadvisor.com/prodinfo.asp?number=ATASP4100B |
New member Username: CrazyloofPost Number: 6 Registered: Feb-08 | Went ahead and bought a Sony SA-W3800 Performance Line 15" 200-Watt Subwoofer after reading about it quiet a bit. |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 6455 Registered: Feb-05 | Good luck... |
Silver Member Username: DmitchellOttawa, Ontario Canada Post Number: 696 Registered: Feb-07 | Sony are not known for their subwoofers. Or for audio gear in general. |
Gold Member Username: NuckPost Number: 9851 Registered: Dec-04 | Alas poor l t, I knew him well. Now suffering the slings and arrows of outrageous audio misfortune and rambunctious purchase. Isn't that a Sony ad? |
