Loss of 33 RPM on Technics SL-23
Username: God_is_american
Hi guys, I've been reading another forum post with information about the SL-23 but didn't find anyone with my problem. I scored the SL-23 from my grandparents yesterday, probably hasn't been used in 15 years. It worked fine for the first day but then this morning whilst playing it jumped up to a much higher speed, I guess it's 45 but I don't have any 45s to check. It seems to play the same speed whether the switch is on 33 or 45.
Does anyone know what could be causing the problem?
I have some experience with electronics and I am going to try replacing the pots today as was suggested for a different problem in the other post.
Username: Jan_b_vigne
Dallas, TX
Post Number: 12331
Whenever a component has been sitting for a length of time it should never be plugged into a wall outlet and hit with 120 Volts. The best way to bring a component up to working voltage is with a controlled voltage device such as a Variac. You've probably damaged a component in the speed control section of the table, most likely a capacitor. I have no idea which one it would be on this table and a failed capacitor can take out other components in front and behind itself.
OK, thanks, I'll see if I can see any damaged caps.
Also, I'm in Australia so it's 240 Volts @ 50 Hz
Username: Jodokes
Sunrise Beach, Missouri USA
See the following
http://www.artandtechnology.com.au/audio/technics-sl23.html
It provides complete repair info concerning speed issues.
Username: Nuck
Post Number: 13436
Great link, HZ
Welcome to ecoustics.
