New member Username: CrazyloofPost Number: 1 Registered: Feb-08 | This is a rather simple question, Considering I'm on a budget of about 175$. I have a harman/kardon AVR20II receiver In my room. I need to know if I can hook a non-amplified car system up to the receiver and get enough power to shake the room. I currently have 2 rather old Pioneer CS-G2O3's hooked up to it and they give it quite a kick but I'm looking for more. So would I be able to hook something like this http://www.sonicelectronix.com/item_1999_Visonik+V123BP+Dual+12-+BP+Series.html# up to it? |
New member Username: CrazyloofPost Number: 2 Registered: Feb-08 | or possibley this system. http://www.sonicelectronix.com/item_10592_Dual+XOBP12D.html |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 12320 Registered: May-04 | . If you're looking to spend $175 or less on a sub, don't buy anything. Save your money and buy a real subwoofer. |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 6421 Registered: Feb-05 | Ouch....but true. You won't have to save long for a Hsu or Outlaw and they will beat the pants off of anything you can buy for $175. |
New member Username: CrazyloofPost Number: 3 Registered: Feb-08 | I didn't ask for opinions on what I should do. The question is as stated and the only price I'll be spending in 175$ ![]() |
