New member Username: Travisty_sHouston, Tx Post Number: 1 Registered: Feb-08 | i know i need help connecting the speakers and the dvd/cd player and any advice on maybe getting new speakers would be appreciated. well now to what i just bought. i got a used yamaha rx-z1 from someone on craigslist, with it he coupled a polk sound bar and a psw505. what do i need to do as far as what scene to set for just listening to music? and should i invest in better and different speakers? thanks ahead of time for your responses. |
Silver Member Username: DmitchellOttawa, Ontario Canada Post Number: 692 Registered: Feb-07 | Are you more interested in listening to music or watching movies? |
New member Username: Travisty_sHouston, Tx Post Number: 2 Registered: Feb-08 | well 50/50 really, the only caviat i have is my apartment is rather small now, but i do both at resonable volumes. |
Silver Member Username: DmitchellOttawa, Ontario Canada Post Number: 693 Registered: Feb-07 | The rx-z1 is not a bad receiver. If you're interested in HT I'd get rid of the Polk sound bar and get some half-decent fronts/surrounds/center. For listening to music the sound bar will probably wholly inadequate. |
New member Username: PreposterousPost Number: 2 Registered: Mar-08 | My HT setup consists of Athena F1.X setup (Front, Rear and Center) along with a Bic H100 sub, which works pretty well for my modest room. This is not the greatest setup for music but works especially well for HT applications. If you were more interested in a more musical setup, consider the Canton LE207s in lieu of the Athena WS300. http://www.accessories4less.com/make-a-store/item/CANTLE207SLV/CANTON/LE207-Silv er-3-way-Tower-w/Dual-5-Woofers-Pair/1.html Good luck with your setup PS: Get rid of the soundbar ![]() |
