Preamp for McIntosh 60
Username: Vocalionrecords
Newbie here. I just bought a 1957 McIntosh mono tube amp, and need some advice on preamps from the experts. I'd like to keep it under $1K. Most of what I listen to is on vinyl and is about 50% acoustic and 50% electric, 1950s-60s era, if that helps. Any info or advice appreciated.
Username: Jan_b_vigne
Dallas, TX
Post Number: 12306
Are you looking for a mono pre amp or a stereo preamp with a mono switch?
Either one, I suppose a stereo with a mono switch would be better, though I listen to little stereo.
Dallas, TX
Post Number: 12307
I'd look at a pre owned Mac pre amp. Try sites such as Audiogon and Audio Classics for ideas.
http://www.audiogon.com/
http://www.audioclassics.com/
