Hello everyone, and thanks for your time. I have an old sylvania amp whose right speaker crackles when the volume is adjusted.. anyone know how to fix this? Can wd-40 be used somehow?
Caig Deoxit sprayed in the pots and switches (from the inside) usually fixes it. For more in depth instructions I recommend that you ask the same question at AudioKarma. Don't use WD40.
