Opening up a speaker
Username: Marclau
Probably a silly question but is there any harm in opening up a speaker from the terminals at the rear to look inside?
Just wondering about how the terminals are connected once you connect the wire cables?
I wont be touching the box.
Yes silly question I know..........
Username: Marclau
Was actually for the Wharfedale XR1000
I actually opened them from the rear unscrewing the cable mounts and slightly pulling out mount.
I then had a quick look and then proceeded to screw everyhting back up.
Hope this was O'K to do?
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 646
Sure, why not? It's good to be curious.
Just don't fill your speaker with concrete.
Inside joke...
Username: Marclau
Thanks David......that was actually it....I was curious....
I actually opened them from the rear unscrewing the cable mounts and slightly and carefully pulling out the mount. (small looking motherboard/circuit board)
I then had a quick look and then proceeded to put everthing back and screw everything back up.
PS Reason for the answer from professionals is that this is causing a debate on one of the Hifi forums.
One chap mentioned that it would have ruined the speaker by letting air in........??
Username: Dmitchell
Post Number: 647
Letting air in? LOL, ok.
Username: Nickelbut10
Post Number: 1164
LOL letting air in? Tell the chap to sell his equipment. He is an idiot.
Username: Nuck
Post Number: 9776
In a lot of cases there is a big open tube to let the air in...and out.
Y'all might want to look into another hi-fi forum.
Ohh, you just did!
Username: Stryvn
Wisconsin
Post Number: 675
Letting the air out is ok.
Letting the smoke out is not.
Username: Nuck
Post Number: 9780
I only did it once, man.
Username: Jan_b_vigne
Dallas, TX
Post Number: 12264
"Reason for the answer from professionals is that this is causing a debate on one of the Hifi forums.
One chap mentioned that it would have ruined the speaker by letting air in........??"
Sounds like wiley has found a new forum.
Post Number: 1171
LOL
Username: Jaw
Post Number: 182
If the Wharfedale is a Revel rebadge, all bets are off.
Username: Marclau
hahahaha you guys........only a member of this forum for a few days and already I feel the love......:-)
Username: Nuck
Post Number: 9782
Welcome, friend.
