Silver Member Username: DmitchellOttawa, Ontario Canada Post Number: 639 Registered: Feb-07 | I know this is a very controversial subject, but I have to ask. I'm want to buy a half decent set of interconnects for my new Cambridge Audio 640C. I've seen on ebay both Audioquest Sidewinders and Kimber Kable PBJ up for auction at reasonable prices. Which ones would you guys recommend? Are these two even in the same league? I get the impression the Kimber is a little better (based solely on price...). |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 6217 Registered: Feb-05 | I like the Kimber Timbre a lot better than the PBJ which sounds a bit rolled off at both ends. Also the Analysis Plus Oval One is a good budget interconnect. |
Silver Member Username: DmitchellOttawa, Ontario Canada Post Number: 641 Registered: Feb-07 | Thanks for the tip Art. I'll pass on the PBJ (does that stand for "peanut butter & jelly?") |
Silver Member Username: Malco49Baltimore, Maryland Usa Post Number: 142 Registered: May-05 | i have audioquest sidewinders with the same cd player and am very happy with da sound! |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 12253 Registered: May-04 | . https://www.ecoustics.com/electronics/forum/accessories/342576.html |
Bronze Member Username: MorphPost Number: 13 Registered: Feb-08 | If you're interested in a set of audioquest king cobras, send me a note! Check out the reviews on them.. ;) |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 6228 Registered: Feb-05 | That might be a good deal David...hopefully you sent a pm. |
Silver Member Username: DmitchellOttawa, Ontario Canada Post Number: 643 Registered: Feb-07 | I did. Still waiting to hear back from Darren. |
Gold Member Username: Stu_pittIrvington, New York USA Post Number: 2473 Registered: May-05 | I own a pair of King Cobras. They're a very good interconnect. I don't know your system to speculate about synergy. What are you running for speaker cables and how long are they? |
Bronze Member Username: MorphPost Number: 14 Registered: Feb-08 | Sorry for the delay, trying to get ready to enter the rat race tomorrow! I sent you a PM, Dave!! ;) |
Bronze Member Username: Scorpio1Philadelphia, PA USA Post Number: 67 Registered: Nov-07 | I too used the King Cobra interconnects until I parted with my Adcom gear in favor of an all Naim setup. |
Silver Member Username: DmitchellOttawa, Ontario Canada Post Number: 644 Registered: Feb-07 | Stu, I'm using generic 12 gauge speaker cable from Home Depot. The runs are fairly short - my furthest speaker from my amp is maybe 8 feet, and I tried to keep the run lengths identical for both speakers. |
