Which one?
Adam Steiner
Out of these recievers which one would you recommend.
onkyo tx ds595
HK avr320
HK avr310
Sony strde875
H/K320. JandR.com has it for $500 U.S.
I own the 510 and 310 but the 320 represents the best bargain out there in any terms of choice...sound quality, upgrade path, features, etc. However, the 310 can be had for $300-$350 or so on the used market and does represent a significant savings with a few less features.
The list you got I will certainly choose onkyo, harman are over priced receivers, and they are not as clear as onkyo, but if you want to compare onkyo with anything check denon avr1802. its in the same price range as onkyo, and take my advice stay away from sony or any other mass producers (kenwood, pioneer).
