Please, I need help determining the best sub sattelite speakers. I am looking at the mirage omni stat micro, Energy Take2.5 and Polk 6700 unit. WHICH OF THESE PERFOM BEST IN A 15X22 SQUARE ROOM WITH 12' CEILINGS. I am using a Onkyo 501 receiver.
PLEASE HELP. And thanks
Hawk
I personally think the Mirage Omnis are by far the best of the three systems you suggest, but I would also recommend the JM labs Sib/Cub system. It has a 5" mid/woofer which can push more air in a large room. Despite the advances in speaker design, the laws of physics remain immutable. The larger the space, the larger the speakers you need to fill the space. Despite the larger mid/woofer driver, the Sibs are in a pretty small box.
The Energy Take 5.2s are simply too small for that room (they are meant for rooms less than half that size). I also think the Polks are too small, as well.
Arj
I agree with Hawk, Try the Mirage OMNISAT's they sound great and look good too !
