Gold Member Username: ExerciseguyBrooklyn, NY United States Post Number: 1726 Registered: Oct-04 | http://blog.hometheatermag.com/ces2008/011008onix/ I'm not sure I've ever seen a driver like this, anyone (and you know who your are) care to explain the benefits of this thing? It looks like they'll be some interesting stuff coming from Mark @ AV123 in the near future. http://av123forum.com/showthread.php?t=27907 |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 12052 Registered: May-04 | . Open baffles I can explain. "Dual drive magnet"? I know nuthingk! . |
Gold Member Username: ExerciseguyBrooklyn, NY United States Post Number: 1728 Registered: Oct-04 | Now I'm interested! |
Platinum Member Username: Jan_b_vigneDallas, TX Post Number: 12056 Registered: May-04 | . If I see correctly, they are using the "dual magnet" drive in the cheaper speaker but not the higher priced? That seems odd. Typically, placing anything that large in front of a smallish driver which works up into the midrange isn't a great idea due to reflections off the obstruction. That's quite a power cable connector they've found. Audio bling! . |
Gold Member Username: ExerciseguyBrooklyn, NY United States Post Number: 1729 Registered: Oct-04 | Yes, Dr. Freud might have a thing or two to say about that cable connector. I'm still not sure how you can hang a large magnet off a voice coil with no support other than the coil itself? |
Silver Member Username: QuinnPost Number: 169 Registered: Aug-05 | Can someone explain how that magnet right in front of the cone doesn't mess up the dispersion of the sound waves? |
