Silver Member Username: HifisoundguyPost Number: 194 Registered: Aug-06 | If you are looking for the best upgrade in your system then just try one of these Oyaide R1 ac outlets! The place I got mine they stay out of stock all the time...it takes a while to get them www.cryo-parts.com/oyaiderec.html Do a GOOGLE search for...(Oyaide R1 forums)....lots of good stuff on these outlets there! |
Silver Member Username: DmitchellOttawa, Ontario Canada Post Number: 526 Registered: Feb-07 | I thought the other thing was the BEST? |
Silver Member Username: HifisoundguyPost Number: 195 Registered: Aug-06 | The Crystal Clear is the best contact enhancer that I have used....these outlets..WOW! the BEST $130 YOU WILL EVER SPEND!.............. |
Silver Member Username: Nickelbut10Post Number: 992 Registered: Jun-07 | Randy..are you some virus? You remind me of a spam email..you know the ones that send you all those viagra emails to your work email, and all of it is the "Best". Randy can you post something about what you feel is the BEST cd out there today, or what kind of music, you think is the "best". I would rather hear that, then some stupid tweak. |
Gold Member Username: NuckPost Number: 9561 Registered: Dec-04 | The Clear...hmmm...ism't that what Barry Bonds used? It must enhance something. |
Silver Member Username: NmytreePost Number: 161 Registered: Aug-04 | Hospital Grade Orange outlet, $10.00 at Lowes or Home Depot. They work just as well and look groovy in orange![]() ![]() |
Silver Member Username: NmytreePost Number: 162 Registered: Aug-04 | http://electrical.hardwarestore.com/14-53-double-outlets/ground-hospital-duplex- receptacle-671437.aspx?CAWELAID=42559931 |
Silver Member Username: NmytreePost Number: 163 Registered: Aug-04 | http://electrical.hardwarestore.com/14-53-double-outlets/hospital-duplex-outlet- 620298.aspx |
