Infinity Beta Center with Primus Fronts?
Username: Billru44
Post Number: 23
Hey
I have the Infinity Primus 362 fronts. If I were to get a center channel from the Infinty Beta line, would that be a good fit? (BETA C360). Just curious. Or should I stick to a center from the Primus line?
Username: Jan_b_vigne
Dallas, TX
Post Number: 12007
Buy what fits the space. Once you place a center channel speaker in a different environment than the front speakers, they are no longer timbre matched anyway.
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 515
When in doubt, buy the more expensive one.
But seriously, though, I'm a big believer in matching fronts and center.
