Hello, I have a 1994 25th anniversary Trans am that is a hatchback. This is my first time dealing with subs and I was looking to put in two high quality 12s. Though I hear subs can interfere with the hatchback door and cause problems? So if anyone has any suggestions or opinions they would be highly appreciated. Thanks
only problem you're likely to get is your hatchback door is gonna vibrate so so much it'll sound like bad distortion (seeing as it's a 1994 model i'm assuming there are a few rattles here and there and in hatchbacks the rear door usually comes first ^_^)... so fitting decent rubber seals to the door should solve any problems.
